swimmin' for shore
- Oct 25, 2004
- 490
I was looking on ebay. I even emailed one of the sellers for info., but received no answer. I thought some of you might be able to give me a better answer.<br />I have an 80 gallon air compressor. It holds well at 120 psi and does a good job of keeping up with my small sandblaster. This blaster is just a roll around bin that gravity-feeds to a hose and gun at the bottom of the tank. It's an older sears blaster, or at least the gun is. I've blasted aluminum boats and I've blasted light paint and rust from trailers with this. It works decently, using 30 grit silica. <br />I want to move to faster, though. I've been doing a lot of these little boats and trailers. I have 2 larger trailers to blast and paint now. There's a 400 dollar blaster on ebay that advertises 1 sq. ft. per minute. This would be faster than my blaster, but I know it's all relative to what you're blasting. Does anyone have any experience to add as far as what is a good buy, coverage speeds, etc...? I don't mind paying the 400 dollars. Anything more than that would be a push. However, I've sold a handful of aluminum boats and trailers, so this will pay for itself if it's significantly faster. Thanks in advance.
