ThomasHill
- Apr 8, 2009
- 34
Got a new manifold for the 77 Galaxy I obtained. Installed it along with new gaskets and fired the engine up. After it ran for a couple minutes it sounded good. Temp about 140 with around 40 pounds of oil pressure. Are these within range? I have one last mechanical question. The stern drive does not raise just using the up button. Going down it works fine and when I pust the middle and top button it will raise. I bypassed the trim sender and now the middle button will raise it and the bottm button will lower the drive. Am I looking at a new sender or can those be repaired. Is it the switch maybe.
Thanks
Jack
Thanks
Jack
