the 1st oner may have used auto oil
DANIELLE
if so whould it have damaged the engine? or could we flush it out and clean it on 1986 75 hp evinroude and i did order my manual to change the impeller. thx for the help.<br /><br /> :) <br />danniyelli
FlyBoyMark
Ensign
Re: the 1st oner may have used auto oil
I don't mean to insult you but could say all this again in a little bit better english and better spelling? I have no idea what your trying to say.(or anybody else maybe...)
Solittle
Dan - Not much you can do at this point. I would drain every drop of fuel from the tank, lines and carbs. Squirt aome oil into the combustion chambers and turn by hand. Add fresh fuel mix (50:1 TWC3 oil) and fire it up. You might want to do a compression check after you run it also. Let us know.
FlyBoyMark
Ensign
If you used automotive oil to run the engine for a very short time, it should be okay. Outboard manufactures alow this for EMERGENCY purposes. The older the outboard, the more able they are to run for a short duration on automotive oil.
DANIELLE
sarry flyboymark for the spelling mistakes. i was at work, phones were ringing, had to answer i typed it hastily. solittle thank you for the help. i will let you know how things work out.<br /><br />PS first time boat owner<br /><br /> :p <br />danniyelli
sparkroost
What motor oil brand/type was it?
mbrueck
My dad bought a 1956 Johnson 5.5 (I believe) from a guy that rebuilt old and antique motors. He said to use SAE 30 for the motor and not 2-cycle oil, I think at 25:1 (maybe it's his way of ensuring repeat business?). This motor ran flawlessly for the 3 or 4 years my dad had it.
FlyBoyMark
Ensign
Thats rite 30 weight oil, should be straight mineral oil (not detergent but excusable if it is..) I know lots of people (years ago..60's ) that did this with no "apparent" ill effects. But again...EMERGENCY use on newer engines.
graddy
Flyboy; there is no manufacture in the world that would advise a person to use auto oil in a two-strok engine. Not sure where your getting your info. I guess if the person was stuck on a island and all he had was 4-stroke oil.
rickdb1boat
Outboard 2-stroke oil wasn't even developed before the 50's, so they all were running straight weight motor oil before that. It would do in a pinch.
SlowlySinking
Master Chief Petty Officer
Correct me if I'm wrong, :confused: but, doesn't 2-cycle oil stay mixed with the gas whereby 4-cycle oil separates from the gas????
graddy
All motor oil is required by law to mix with gas.
rolmops
Quote from a 1957 Johnson rde/rdel manual.<br />"We recommend using a reputable outboard motor oil or SAE 30 grade automotive engine oil(not heavy duty)"<br />You may have fouled up your injectors a bit but nothing some properly mixed fuel and carburator cleaner mixed in with your fuel can't take care of.
marty_scher
I'll try to put my prior pump-jockey skills to work here.<br /><br />The key for using 30WT in 2-strokes, is that is needs to be NON-DETERGENT, unlike most multi-grade engine oils are today.<br /><br />I believe detergents had too good of cleaning effect when burned, thus possibly increasing wear that the oil was supposed to reduce.<br /><br />In the 50's , there was not much (if any) detergent oils available, so it was probably not referred to much, concerning outboard premix.<br /><br />I would suggest filling the tank with good premix and go boating. If it has not fried in 16 years, it is probably fine.
DANIELLE
we took the boat out on sunday after draining the old gas mix out and refilling. it bogged a little at first but then it ran great. thanks for the help.<br /> <br /> :D danniyelli
