rhomesteader
- Aug 13, 2006
- 27
I am changing the impeller on a 1983 Mercury 9.8hp. but I have run into the same problem on a 15 hp older Johnson.
How do you get the little flat key that drives the impeller to stay in place, on the flat spot, on the drive shaft while putting the empeller in place?
I'm sure the experienced and the pros on this Forum must know a few tricks. Hope you will share. This is the hardest part of changing the impeller on the smaller outboards.
(I don't know if that key has a special name or not, but I've called it several special names!)
