Thanks Laddies for the merc 650 help!
jbjennings
Got a new rectifier installed today for my '75 merc 650. Put it on and checked voltage at the battery on slow idle----12.7 Volts, at fast idle----12.9 volts. I'm very pleased! This motor now runs/shifts great, starts easy after a choke solenoid shim, doesn't leak water into the lower unit, and now charges the battery. Not bad for a 34 year old motor!
Thanks for the help. If you don't mind, if it should be charging more, let me know. :redface: Anyway, the voltage was DROPPING at fast idle before the rectifier change, so I believe she's fixed.
Later,
Jason
