ezeke said:. If the battery is a deep cycle dual purpose marine battery, you can expect that it will be showing around 13-15 volts on your voltage guage while you are running, .
R.Johnson said:Dis-connect one battery cable, it does'nt matter which one. Place a volt meter in serie's with the cable, and the battery post. or other word's direct connection. If volt meter show's a reading , you have a drain, and will discharege battery. This is with key switch off. Dis connect component's until you find drain.
teslaman said:Whatever you do, do not stick an ammeter directly between the poles of the batt. This would subject the batt to zero impedance and blow the fuse in your meter.
Sparks may fly also!
