Testing Oil injection on a 30hp yam
jedimaster
I have a 1997 yamaha. How can I safely test to see that the oil injection is working?
99yam40
Re: Testing Oil injection on a 30hp yam
If you were truly a Jedimaster the Force ( and probably you service manual)would tell you to mix some fuel and oil at 50/1, make sure it is all the way into the motor, and then disconnect the oil line and measure the volume of oil that comes out or mark the tank and see if it moves about the volume that the motor require at a given RPM, like the manual should give in a chart
