I've stripped a 1977 Merc 20hp as it was only running on one cylinder (stripped as I needed some of the parts for my other motor). Occasionly the motor would run on both cylinders but after five minutes (or when it was warm) it would only run on one again.<br /><br />Now I'm 100% sure it either the Switch Box or Engine Block that's the culprit. But how can I test them when they're seperate (not attached to the motor)?<br /><br />Can a cold compression test on the block give a 100% safe result?
