I’m trying to track down the cause of hard starting when cold (takes roughly 10-15 five second cranks, including throttle pumps, to start, starts well when warm, runs and idles well). This is on a 2015 3.0L, low hours. Compression test is good. Full tune up (plugs, wires, cap, rotor, fuel filter), oil change, fresh fuel, removed carb and spayed carb cleaner through it (looked clean start with though).
I went to check the resistance on the ignition coil, following the service manual procedure, but it’s really strange, on every terminal combination I’m just getting an open circuit reading (i.e. no continuity). I spent a good 20 minutes, tried different test leads, new multimeter, continuity checks touching leads together.
I’m really scratching my head on this one. If there actually was no continuity at all I would think that the motor wouldn’t fire/run at all, which it does just fine once warm.
What do y’all think?
