AnglersEdgeNY
- Oct 13, 2007
- 34
86 johnson 225
How would I go about testing if my batteries are charging with a Blue Sea Add a Battery System installed.
With the engine running I tested across the batt terminals and got a reading of 12.6ish volts. I know the relay controls the charging some how.
I'm a little suspicious because my tach isn't working.
I did the test as Joe Reeves described for the 35 amp rectifier and the results were that my tach is bad. I guess I just want to make sure I'm charging the batteries.
Mike
Mike
