55Crestliner
- Aug 31, 2004
- 192
How and why does one use a test wheel?<br /><br />Do you use it to see if your motor will make the propper WOT rpm? Or is it just a way to test under load?<br /><br />Example - my motor is doing X rpm with a given prop. Maybe with this same setup, if engine wasn't running it's best it should do a higher rpm?<br /><br />Does the test wheel show condition of tune is what I'm asking.
