Test wheel for '86 Johnson 120 V4-newbie
USCGCPOMK
Greetings, I am new to the forum and just getting started in the whole interweb forum stuff. Please forgive me if I seem un-educated. I recently acquired a 1986 Hydra Sports 1800CC with a 120 V4 on the back. It was abandoned in a filed for a few years but the hull is solid, aside from about 20hours of compounding I did to remove the oxidation. The engine I got running, compression is about 90 on all 4 holes. I know there were a few "mechanics" that worked on the boat before I adopted it so I'm not sure what they messed with. I am going to set everything to factory and do a throttle sync this weekend. I have searched everywhere to find a test wheel for this boat and came up with P/N 386246. Unfortunately these are nonexistent for sale anywhere. I read that the 315983 will work as well, can anyone point me in the right direction? Not really excited about timing WOT on the water.
BTW I have been a marine mechanic with the USCG for 18 years, pretty decent with this stuff, just not an expert in mid 80's outboards lol. I do have a SELOC and CLYMERS manual for this engine.
hardwater fisherman
There are some videos on youtube that explain how to do timing at cranking speed without the motor running. Or there is a member here that gives good instruction on this. There is another recent post here about this.
before doing anything, verify the compression again. 90 psi is low.....
boobie
You can make a test wheel out of an old damaged prop by cutting the tips of the blades off equally.
USCGCPOMK
Wasn't sure on the compression, OMC doesn't really put out a recommended level, just says they should be within 10% of each other.
interalian
Curious: how much do you leave on the hub? I have a ratty old prop that may be a candidate for such use.
boobie
If possible have 2/3 to 3/4 of the blade left on the hub.
flyingscott
Forget about making a test wheel for the motor. Google joe reeves method for timing your motor. It can be done in the back yard and is much safer. If you make a test wheel you better make sure it has a good hub, because if it slips motor could be damaged or someone could get hurt.
boobie
Test wheels are used for more than just timing a motor. Good for trouble shooting high speed running problems among other things. I wouldn't have a shop with out them.
USCGCPOMK
Did the Reeves timing, seemed to work pretty good. Will confirm on the water. Just have to deal with the rest of the gremlins, thanks a lot.
