Re: Test propeller
Thanks for the reply Frank. I was misinformed :redface:
If used in a tank, meaning the test prop, can you run the motor at W.O.T?
I use muffs atm, but I want to see if there is a way to run the motor at W.O.T without being on the boat in the water.
