TEST POWER PAK?
YLABM
HOW DO YOU TEST A POWER PAK FOR 1996 EVINRUDE 25HP 3-CYL
hondon
Re: TEST POWER PAK?
No tests for pack. If all the inputs levels are correct going into the pack ,but you've got nothing coming out ,then the pack is bad. You will need a DVA meter to measure those inputs.Much different than a conventional volt meter in that it reads peak voltage in a short time and is adjustable too a broad range.
