Can anyone tell me a quick test for the enrichner valve on my early 80's Merc. inline 6 90hp outboard? Motor is new to me, came on pontoon I just picked up to renovate this winter. On the muffs, idle seems rough and I'm getting unspent fuel in the exhaust. (running rich). When I pump the bulb at the tank fuel flows out the bowl of the top carb and through the enrichner valve into the crankase. Shouldn't that valve be closed until I activate by pushing key? Could that be why engine is flooding?
What does the brass knurrled nob on the top of the enrichner do? If I close it even slightly with the engine running (although rough and looking to cut out any second) the rpm's pick up and I have to screw counter clockwise to bring the idle back down. Is this normal?
Also, I've tried draining the float of the top carb a few times and it's always empty. Is that because the enrichner valve is continuously letting it drain out? I can get fuel to pour out the top carbs float drain if I pump the bulb with the drain plug out. Any and all thoughts are welcome as I'm trying to figure out if I need to rebuild carbs to cure stuck float or purchase a new enrichner valve. Thanks!
