Terrible fuel comsumption!!
danny k
I have a '94 Johnson 150 on a 28' pontoon. The last trip out I had 7 other people on board and I normally run at about 3000rpm and this time out it used alot of fuel. I'm not sure if it was a strong headwind or what. The motor runs great. No missing, excessive smoking, sputtering, etc. How many GPH should I expect to burn with this rig at 3000 rpm with 7 or 8 souls on board?<br /><br />Thanks guys,<br />Danny K.
angus63
Re: Terrible fuel comsumption!!
What is your wide open throttle rpm? My 1995 175 oceanpro burns appx 7-8 gph cruisin' on plane at 3600 rpm. WOT is about 5400 rpm on a 3500lb loaded 22ft. Trophy.
danny k
WOT rpm is about 5500. Considering the weight of boat, motor and passengers I'm guessing around 4000lbs for boat and motor and another 1500 for passengers, ice chest, etc. or a total weight of about 5500 lbs. I used 10 gallons on about a 40 minute run at 3000 rpm.<br /><br />What 'cha think, angus??<br /><br />Thanks,<br />Danny K.
angus63
Theoretically, you should burn about 15gal/hr at WOT. You are at 55% throttle and burning appx 13gal/hr. Alot depends on load, setup, hulltype,etc....<br />I'm not familiar with pontoon hulls, but you are burning nearly twice what I burn at similar RPM. You are 6' longer and appx 1500 lbs heavier.<br />I guess if 7 or 8 people each chip in $20, problem solved!!!!!!<br />Might want to check for leaks and verify set up height is optimized. <br />Indeed your motor seems more thirsty than expected.<br />Good luck
danny k
I forgot to mention this pontoon has a 8'X10' aluminum top, and at 3000rpm this top creates a alot of drag. Due to the angle of the motor and transom I don't have much room for trim. I have to run trim practically all the way down, probably 90% down.<br /><br />I guess your right. $20 per soul would cover it!!<br /><br />Thanks,<br />Danny K.
