Terminal Extender?
vettenuts
Got my DVA in today and checked the Sensor Coil and Charge Coil, both are within specifications. I want to check the Power Pack but I need a way to extend the terminal on the coil. Can these be bought locally or is there a home made version?
One of my coils is out of specification on the secondary side so I need to add that to the parts list when I finish.
jonesg
Re: Terminal Extender?
I stick the long steel probes on mine down the shielding on the plugs , works on powerpack packard plugs.
vettenuts
Got it, found an old spare spark plug wire fitting and molded it to shape. Got near zero voltage out of the power pack (0.8 volts), which was a surprise. I was expecting weak but not zero. Everything else checks out so I am planning on picking up a new power pack and one coil to see how things shape up.
