Temperature sender wiring
egclassic
1996 4.3LX Gen+
Do the wires attached to the temperature senders on either side of the thermostat housing just unplug? They have what look to be molded rubber 90 connectors, but I am unsure if they pull out or not. I gently pulled on one of them and it seemed to "click", but I just pushed it back on before I broke something.
Thanks
jake1z
Re: Temperature sender wiring
on my 3.7 and my 454 they just pull right off
dubs283
yep - pull em right off
the ends "slide" over the stud on the senders
one is for the guage (solid tan) - the other is for the warning horn (tan/blue)
Alpheus
1996 4.3LX Gen+
Thanks
I wish I was there right behind you the exact moment when you pulled on that wire and felt the click. I would have yelled and I bet you would have jumped ten feet in the air. :D
Thats pretty delicate if you just pulled on it hard enough to feel just one click...
egclassic
Like I said, I just did not want to pull on wires without knowing the connection.
