morning all.
well i have 2 questions.using an infrared temp gun ,what temp range could i expect to see on my 1980 70hp johnson while on the hose with muffs after 10 min idle? what i am seeing is 107-110 degrees. ques #2 what is the proper way to fill a tilt and trim unit? i think the motor is up with lock in place and the rams retracted fully
and also to bktheking my stator was the problem,charging like a champ. thank you so much for the advise and guidance thruogh all the testing procedures
to all that donate time and knowledge with answers ,thank you guys for being here and doing what you do day in and day out.again thank you VERY VERY MUCH.
