temp switch
mobgod
need a little help plz i need to test the switches what is the best way to do this without the motor running i have two switches it's a Johnson 200 TXL77C
mobgod
Re: temp switch
can anyone help me out with this ?
boobie
Re: temp switch
There's a procedure in the OEM Factory service manual on how to do it.
boobie
Re: temp switch
Is it a factory manual or something like Clymer or Seloc ? If it's factory there should be some dates or model yrs on it.
mobgod
Re: temp switch
yes it's the 1977 service manual orange on top than white says for 175hp tx77 txl77 and 200 hp tl77 txl77
boobie
Re: temp switch
Go and look in the power head section. It should be in there
boobie
Re: temp switch
Sorry about the misunderstanding. I thought you were talking about about the temp senders that came with the mtr. I have no idea how to check those out. Maybe somebody else will chime in.
laderwell
Re: temp switch
Dude that is a added surface mount temp sensor, you can get a gage for it here and new sensor if you want http://faria-instruments.com/store/index-mart.php?cat=Temperature Sender, they are real good so you can run to guage to read Farenheit/Celcius. The wire coming out in the top left corner is your other that just gives off a horn sound that is on most johnsons. Just google T5026 and look at the image .
hope this helps/ mike
