Hi all,<br /><br />I want to check/zesz my overheating switches, While searching the board, I found an old reply by OBJ<br />like:<br />.., find the tan wire coming from the heat sensor on the head. It will be a tan colored wire. Pull the rubber cover back to expose the knife connector and take it apart....<br /><br />My engine 90 HP OMC 1991<br />Are these the 2 holes, each on the right side of a cylinder block between the cyl.s, one cable going in, looks like some rubber or foam is inside ?<br /><br />I cant see the color of cable of "foam", because some preowner has obviously used a black spray can to beautify the whole engine !!!
<br />And I cant find a picture in my Seloc manual.<br /><br />Can I safely get these switches out ??? In an old topic there have been a heck of problems to get new ones ????<br /><br />Thank you all
