Matt DeYoung
- Feb 19, 2005
- 9
I am rebuilding a couple of Merc model 250's. I decided since all the cast iron is now new, I would add closed cooling. The carb is a Holley 600 vac sec and requires an electric choke. This needs 1 temp sensor. The other temp sensor is the one that goes to the gage on the "dash". The thermostat housing that came with the closed cooling kit came with only 1 hole for a temp sensor. When I replaced the intake manifold it provided (2), 1/2" npt ports on the front of the engine. Maybe this is a good place ? <br />I have 3 questions :<br /> 1. Do the sensors need to be on the engine block side of the thermostat or the housing side.<br /> 2. It there a certian type of sensor I need for each application<br /> 3. Where can I get them ?
