Temp. Questions
I have a buzzer installed it has two mounting tabs for wiring neither are labeled. I have an orange wire from engine harness that is labeled "heat" in manual.Itake it that goes to one tab, is other tab to ground? I would really like to install gauge. Are there any that would wire right in or would i need to replace the small sending unit in the top of the head? I've been reading many posts and trying to learn all I can and from what I have read,overheating seems to be the biggest killer. Thanks!
roscoe
Re: Temp. Questions
Yes, other tab goes to ground.<br /><br />A water pressure gauge will tell you about water flow problems BEFORE the engine can overheat. Cost os about $50, and an hour to install.
