Hey guys,
I installed a head mounted temperature sender on my outboard motor and also a gauge in the dashboard that is calibrated to the sending unit. They are a matched set to go together. I have two seperate questions now:
1) I have to run one wire from the sending unit to the gauge. What sized wire would I need to run? It is a 12 volt system. The sender is on a 40 h.p Evinrude outboard, 1962 model.
2) Also, I am wiring the gauge directly to the ignition switch so it will turn off when the key is off. Do I need to install an in line fuse going to the temp gauge or is the ignition switch already fused? If I need an in line fuse, what size of a fuse would be required?
Thanks for any info you can give me!
IGGY
IGGY
