Re: Temp gauge for 200HP Mercury
The following info is from the Teleflex FAQ:
What engine temperature gauge do I use on my outboard?
Teleflex has replaced all of its 50-200 degree O/B temperature kits with a more generic kit that can be used on all outboards having a 12-volt battery. These new kits cover a temperature range of 80-220 degrees. The gauge reads C to H with graduated marks in between for reference. The kit comes complete with gauge, proper sender, brackets, and instruction sheet that adapt it to almost any outboard engine. For replacement parts, sender IA96035 must be used with a 50-200 degree gauge. Sender 52320S010 must be used with a C-H gauge. If an IA96035 sender is used with a C-H gauge, the gauge will read at the 200-degree area very quickly. The 120-240 degree stern drive temperature gauge can be used but it will register temperatures in the low temperature area (on most engines) when engine operates normally. The numbers on the face may have no real meaning as actual temperatures. Sender 52320S010 must be used. If sender requires a bracket for installation, use bracket IA55009.
