Coork Johnson
- Feb 20, 2001
- 33
Temperature alarm goes off on Mercury 150 H.P. V-6 out board as soon as key is turned to on position. What appears to be a thermocouple is mounted at rear of cylinder block, wire coming from device is frayed, when part of device was remove a spring was found. This probably is source of problem, my question is how do you remove device from block and how do you replace or repair it ? My Clmer manual does not help out.
