I recently purchased a pontoon boat with a Mercurcy F25ELPT 4-stroke. During the 30 minute pre-purchase water test I noticed the tell tale was only dribbling. The vendor stated that it had been like that the 8 years he owned the boat. My 1974 Mercury 1150 (tower of power) that I have been maintaining over the years, peed like a racehorse when I had it out last month so this piddle from a modern engine doesn't sit well with me. The water flow diagram in the Mercury service manual for this engine shows the flow from the lower unit pump going to the exhaust adapter plate from where it fills the powerhead and, until the thermostat opens, can exit only through the fuel cooler to the telltale. After the thermostat opens, it also circulates the waterjacket and exits throughthe exhaust and idle relief. I pulled the hose off the inlet side of the fuel cooler - no flow at idle speed. I also confirmed the tell hose was clear. I then replaced the impeller on the water pump. The old impeller was still intact but cracking so replacement was needed. New impeller but still nothing from the telltale. I then put a garden hose directly onto the lower unit water tube without starting the engine. I got a dribble from the telltale and all the water coming down the exhaust.
My thinking is that the thermostat is stuck open. That could explain how the previous owner had 8 years without overheating but zero flow at idle and only dribbles at higher RPM from the telltale.
Does this make sense for a modern engine? My 1974 1150 pees like a racehorse at all RPM (it doesn't have a thermostat). I wouldn't have thought the thermostat opening would affect the telltale water flow so much.
