cbass74429
- May 11, 2006
- 120
I have a 2000,200 Johnson. I have replaced water pump two days ago. Whole unit from plate up, to houseing. Vanes are turning clockwise, on pump. Bought uint off this site. At idle it was 11 to 12 lbs. At 3 grand it was 25lbs. Didn't run it super long. Took it out and started it at lake and never had a tell tale or what ever you want to call it. Ran smooth (motor). I removed it (tell tale hole) from cowl and it was open into block. Any Ideas? T stats?
You guys have always steered me correctly in past have alot of faith in you guys...
Thanks David C
Thanks David C
