Re: Tell tale weak?
Leo....That is correct, on that motor the tell-tale is just that, a visual aid, for the water pump. If you have a weak tell-tale then you most likely have a weak water pump, unless something is stuck in the hose which happens from time to time. Try taking the hose that runs to the tell-tale off and blowing it out, if you still get a weak stream, you probably need a new water pump. The 2 holes below the cowling are the exhaust pressure relief holes, when you are sitting in the water and there is backpressure on the exhaust at the prop it comes out of these holes.
