Tell Tale Acting up on 1996 Mercury Mariner 40 HP
Having an odd issue with my outboard. The tell tale mostly spits steam when the outboard is in neutral or at slow speeds. If I give it speed or use the warm start lever at full crank for a few moments, it will eventually start spitting a strong stream. This stream will then maintain at a lower speed and even neutral for a few minutes, but eventually reverts to steam, unless I maintain speed.
I have had one instance where the motor must have overheated, and shut off for about 10 minutes.
Any idea what this could be, or where I should looked first?
Thank you!
Texasmark
Time to replace the impeller in your water pump...blades either have a kink from sitting up, or tips worn off from usage. Get a meanual. I boats sells them......top of the page, electronic or paperback. I used electronic, available as fast as you punch in your CC numbers. Can rent for a time duration, or buy the whole thing.
