Tell me If there is a Trim Sending Unity (Pic)
krakatoa
Hello Guys
My trim gauge just peg to the down position when I turn on the switch, could you please tell me If there is a sending unit here? Is yes , where is it? Please see the picture.
Thanks
Silvertip
Re: Tell me If there is a Trim Sending Unity (Pic)
Very nice picture of the hydraulic pump but that's not where the trim sender would be located. The motor pivots on the tilt tube. You might have more luck looking for it in that area since that's the movement the sender would be sensing. There are wires going to it.
krakatoa
I will look again but Im almmost shure that there is no more cables tghat the ones that comes out from the reservoir. Thats means this situation more strage since the gauge peg the needle to the down position when I turn on the switch:confused: here is another picture.
another one here
Silvertip
The thick gray wire going to the pump houses the trim motor wires. They make the motor run forward or reverse. No trim sender there. In the second picture, the short wire you see under the nuts is merely a bonding wire. There is a white wire in the first picture. What is that?
krakatoa
Take a look to the last picture, there is a "square nut" with a grey tube, the white ones comes from that grey tube.
krakatoa
Here is the part I was looking for Sender Kit Trim #821180A6 for a Mariner 115HP 1993 . Is located @ the starboard side in the Swivel Bracket & Steering Arm.
