Re: Teleflex Steering Cable
My personal experience is that by the time a cable needs lube, its got wear. The wear shows as a slop in the helm because the sheath is worn allowing the inner cable to bunch and slop around inside.
Ayuh,... Ditto what Mark said,....
krakatoa,... Pull your cables out of the motor's tilt tube,+ the steering wheel should turn Effortlessly...
Also Clean,+ relube the tilt tube,.. Your's looks like it's holding some Rust,+ crap...
If that fixes your issue,... Great...
If not,...
I'd replace the cables....
Btw,...
Dual Cables are much Safer,...
But,.. You might be able to convert to a single cable,... Donno...
