jdlough
Master Chief Petty Officer
- Jul 15, 2006
- 824
I just bought a 1997 SeaSwirl 2100 DC with a 175 Johnson OB and standard Teleflex Quick Connect Safe-T (3 turns lock-to-lock) steering.
I have 3-4" play in the wheel. The play seems mostly from a worn helm, and possibly a bit of worn cable. (The linkage at the motor does not move at all during the wheel-play.)
The NFB 4.2 system is recommended for V-6 motors and is 4.2 turns lock-to-lock (current system is 3)
The NFB Safe T II system is 3 turns. The product description says it is recommended only for V-4 motors, but iboat's chart says it's good for up to V-6. If I got this system, would it be no harder to turn than my current Safe T 3 turn system? Would it wear out quicker? Or, should I should I switch to the 4.3 turn NFB 4.3??
Anybody switched from 3-turn to 4.3-turn? Any comments on that? (I'm leaning towards the 4.2 turn system, if only because maybe it'll be harder for my teenage kids to scare the hell outta me with the quick random U-turns.)
Once I get past the wheel-play, my current 3 turn system is not hard to steer, even with the 175 HP.
BTW, iboats carries the Teleflex kits for much less than other sites I've googled.
Unless I'm totally mistaken, this fix/upgrade looks like a rarity in boating - an easy 1-2 hour job of a major component for the DIYer, and cheap!
Thanks,
Jim
Thanks,
Jim
