Tommy Two Stroke
- May 14, 2009
- 65
After refreshing all the seals on my 7.5hp Gamefisher and rebuilding the ignition system, all that was left was to set the timing. Here's a case where the timing procedure spelled out in Tecumseh's 2-cycle engine manual doesn't seem to work nearly as well as leaving the engine's timing set where it originally was. As shown in the attached pics, I used the special Tecumseh timing tool, and a clamped-down dial caliper since I don't have the depth gauge spark plug hole adapter. Per Tecumseh's manual, the engine was set to 0.115 BTDC and the timing was set exactly the way the manual describes. It turned out that the opening of the carb butterfly was happening too late in the full ignition advance travel, when set according to Tecumseh's procedure. This made the engine extremely difficult to start, and when it ran, it would shut down periodically due to lack of fuel in the early part of the ignition advance curve. The wide open throttle position did, however, turn out to be dead-on when set per the Tecumseh procedure.
The point to all this is that Tecumseh's timing procedure may result in an engine that does not run as smoothly or start as easily as before being set this way.
