Alpha gen I, (later MR I think). after changing a gear and clutch dog i was putting the drive back together, i got up to where you install the bearing carrier, which i did and then installed the retainer nut etc... What i have a question on is how far i should be able to pull the prop shaft in and out. i know there is usually some play but i couldn't find in the book how much would be normal. i measured it with a dial indicator and it measured between .040"-.045". That seems to me like a lot but i couldn't find in the book what would even change that measurement other than the bearing carrier not being installed all the way but it seems like it is all the way in, i torqued it down to 210'lbs. any idea if this is a normal amount of play?
