Tech for 150 Force 5cyl
roscoe
Re: Tech for 150 Force 5cyl
What exactly do you mean by a tech?
A service technician?
A technical manual?
It might help to know where you are located.
And what is the problem with the engine?
Ford3316
I am looking for a Tachometer for A force 5cyl. How do I know what one to buy??
roscoe
OK.
All Force 150 hp from 1989 thru 1991 revision "B", use a 20 pole tach.
Newer models use a 12 pole tach, I believe.
Some tach can be switched to be used on a 20 or a 12 pole system.
Teleflex model 53743p or faris # DD2TC9819A are both 20 pole tachs.
If you need a 12 pole tach, most any will do.
