TD20 SeaHorse Only runs if I keep pumping the primer
freakit
I have a TD20 Johnson Seahorse. When I pull the starting cord nothing happens. It pulls freely. Theres 3 pieces of metal on top that move out and inward. 2 of them are missing the springs. So I took off the pull start and got out my 18volt dewalt and put a 3/4" socket on it and start the motor with it.
I have the side cover off the engine so I can see the carb. I pump the primer and see a mist spray out the back from a port that has a copper tube on it that goes to the carb. The primer button doesnt get hard no many how many times I pump it. I move the lever to start and hit the drill trigger. The engine will fire up after a second or 2 of spinning. The engine will run for 2 seconds until it uses up the fuel I pumped in with the primer. After a few times I tried pumping the primer after I got it to fire up. As long as I keep pumping the primer the engine will stay running. If I stop pressing the primer it shuts off. I tried moving the lever from start to fast and same results.
Any ideas on what to look for?
HighTrim
Re: TD20 SeaHorse Only runs if I keep pumping the primer
First of all, I would NOT try to start your motor like that. All you are doing is overtorqing the flywheel, eventually leading to a sheared key.
Fix the recoil.
Carb needs a cleaning and rebuild. This will help.
http://www.pochefamily.org/outboard/CarbService.html
freakit
Thanks for the help. Ill take the carb apart tonight. Hopefully my cork float is ok. I tried looking for a rebuild kit online but read a post where it said they dont exist. This is all new to me.
Any idea what the part is called that sits on top of the flywheel? It has 3 pieces of metal that move outward. Im missing 2 of the 3 springs and the third is falling apart.
I really appreciate the help because im a total rookie at this small engine stuff but hope to learn. Think i came to the right place for help and knowledge.
bonzoscott
You can get those springs at Ace Hardware and others...
freakit
Thanks for the reply. Hopefully thats my problem.
ballsout
does this motor use a fuel pump or a pressurized tank? if it has a pump it sounds like its not working if it runs while pumping gas into it.
HighTrim
It uses neither.
Gravity fed tank.
freakit
No luck at Ace Hardware. I went to 2 different stores plus a Sears and none of them had the springs. Have you bought them from Ace before? Do you have a part number or SKU?
I took apart the carb and the float was rough. The coating was flaking off and it was kind of brittle. I read the guide and it mentions a replacement for a Mercury thats plastic. I'll order the float if I can find these springs.
bonzoscott
No I don't have SKU. I'd have to run back up there to find out but my store had what looked like the same spring. Maybe measure it and look online. The Float: I'm sure somebody can post the link, but you have to sand it down and coat it in "RC airplane dope". or buy a large cork from Ace and grind varnish it. I Doped mine and it works fine. That airplane dope is something else... fuel resistant..
freakit
I'll have to find a pic of a good one. Mine is totally roached. Maybe thats why I couldnt find one. It doesnt even look like a spring anymore. Looks more like a thin piece of mig welding wire coiled and twisted.
freakit
I cleaned the carb and used the airplane dope on the cork float. I then drained the fuel out of the tank and it fired right up. Now I need to adjust the carb because it was popping a little. Its 95 degrees outside so I didnt stay out too long.
I put the prop in a bucket of water while it was running. I noticed a little water spraying out of a 90 degree elbow where Im guessing water runs through to cool the engine. I looked at the elbow and I noticed a little hole in it. Looks like a drilled hole. Not sure if its suppose to do this or if it needs to be replaced.
After getting the carb adjusted the only other thing I need to do is find the 3 springs. I got 3 from Home Depot and tried to modify them myself and 2 of the 3 fell off. Worked for 1 pull and that was it. I'm not giving up yet. I might have to get spring wire and coil up a spring myself. The sites I found with parts go back to the mid 60's. I'm still looking. Any sites you recommend to find these springs?
AlTn
maybe marineengine.com
freakit
Ill give them a call. Thanks
Anyone know if this td20 has reverse and if it does how to switch to reverse?
nwcove
why yes it has reverse!!! spin it 180 deg.....thats reverse.
freakit
Haha. Didnt think of that. My electric troller has forward and reverse. Never thought about spinning it. Duh.
Thanks
