Re: Tcr101
I think you have two problems.
One is the blank screen which I assume you get while sitting stationary on the water with the trolling motor off. The second is a power dip when trolling motor speed is notched up.
Problem one, could be head unit, transducer, or connection. Check for bent pins in the connector blocks and that they are seat firmly at the full height. With the unit it on, and out of water, you should hear a series of "clicks" near the transducer. I am guessing you will not hear them. If someone has a TCR near you and can do transducer and head swap to isolate issue, great. When my old tcr finally died, it had a blank screen and wasn't the transducer. I suspect the output device (transister/op amp) blew in the head unit. Too costly to fix. This might have been caused by a shorted transducer cable. With a multi-meter the transducer should have a high impedance, not just a few ohms.
The tcr is an old unit, and any current $100 unit will have more capability. Don't spend much trying to fix it.
Problem two can probably be fixed with good battery connections.
