Could someone please point out the wisdom (or lack there of!) of removing the TBI system on my 1999 Crownline w/ a Volvo-Penta 5.0 and replacing it with an Edelbrock carbuerator. How much will the fuel usage change? Are there any other modifacations needed to complete the change-over? Thank-you! KenPickle The reason i'm asking is because the injector driver is not working (no pulse to injectors) but the coil driver and advance are working fine. the cost for a new ecm is at least $1200.00 as it has a "MEFI 3" which,I understand,is no longer made.I would need to install a "MEFI 4" which needs a different wiring harness (At additional cost!) Also,the boat will be heading to Mexico (Permanently) and I want things as simple as possible! KenPickle.
