jtmarten
Master Chief Petty Officer
- Aug 2, 2004
- 825
Hi<br />I think I have a problem with my tandem equalizer, but this is my first tandem so I'm not sure. The trailer is sitting under a '78 Anthony 23' Daycruiser with a 454/berkeley setup. The trailer is a RoadRunner.<br />The right side equalizer sits level when on level ground, but the left side always has the rear spring much higher. The equalizer is usually at a 30*-45* angle. I had 2 blowouts at the left rear position on the return of a recent boating trip (275 miles each way) I tried jacking the front spring up slightly at the equalizer - thought maybe it was stuck - but it moved up, and back down when I let the jack down.<br />Is this normal or is there something wrong here?
<br />Thanks much!!<br />Jeff
