Re: Tan Wire In Harness
All the tan wires...tan and tan with different color stripes are for the alarm systems. On a V6 looper, you have two temp sensors at the top of the heads near the thermostats, one coming from the VRO oil tank, one coming from the VRO pump, and one coming from the vacuum switch. I hope I haven't missed one...
The wire is supposed to come out of the sensor in the head, and go directly to a male/female connector..within maybe 2 inches. You can disconnect it there for servicing.
The proper way to fix the sensor would be to get a new temp sensor.
If any of the tan wires are grounded, either intentionally (for testing) or by normal proper operation, the warning horn will sound.
They will not affect the running of the engine. The condition that caused the horn to sound will definitely affect the running of the engine. Overheat, no/low oil, or excessive fuel line vacuum.
