Talk me out of this...
BWR1953
Re: Talk me out of this...
Don't do it... cuz it needs thousands and thousands of dollars in it to make it go. Uh-uh!
salty87
no engine, no outdrive, no trailer
that's not a boat, it's a bill at the dump.
you gonna drag it behind your truck like in that commercial? :) :) (do it!)
nitsuj
Valid points. But for $200? How much can I get an engine for? And an outdrive? And a trailer? So for a grand total of...... And I could have a nice Wellcraft. Lets run the numbers boys....
Someone stop me... Please....
LS1_SE7EN
About $5000 if you do everything yourself and that doesn't include little stuff that will go wrong.
tractoman
If you're going to spend 5 grand, you can find something way better than that, that is ready to go. I considered the same option and figured I'd rather use my money for a working boat and then be able to use it rather than spend the same amount of money and a bunch of my labor to assemble it. Plus if you are married as I am, your wife will be much happier to see a decent boat on a trailer rather than a POS with no engine. Just my opinoin though, if you're up for a major project it may be what you need.
Knightgang
I agree, if you did it yourself, you would spend at least $5K on an engine, geartrain and outdrive... If you had to have someone else install it all, my guess would be closer to $8-10K. Repowering a boat can really cost big $$$.
You can look here on iboats listings and/or on boat trader and find ready to go boats for as low as $2000 up to what you want to spend dependign on what you are looking for.
A project is up to you, but I think I would start with one that has a running engine and drivetrain...
NoKlu
You probably looking at someone else's donor boat. The floors,stringers and transom are probably shot and they took the engine,drive and trailer to use with another hull.
robert graham
NO! Don't do it. If it was an outboard type boat you could find a good used outboard motor to drop on the transom and after you found and bought a trailer,you'd be off and running. But that would be a money pit/nightmare. There's plenty of good used boats around. Check out the Boat Trader magazine. Good Luck!
VeroWing
If it was a nice Wellcraft, it would still have the motor, outdrives, and trailer with it.
CheapboatKev
you'd be freeekin insane.
If you weren't lookin..I'd suggest to keep on not looking..:eek:
Tubingluvr
I think $5000 is a little bit high, at least around here.
I know I could do it for less than $4000.
But then again you can buy a pretty nice boat for $4000 and not have all that labor invested.
mddubya
I've gotta agree with everyone else. For what you'll end up with tied up in that one, you could buy a running boat and enjoy it as you restore it. Granted you'll end up with more money invested in it in the long run, but you'll probably also end up with a nicer boat.
Boss Hawg
I belive everyone should buy a $20 boat for $200 at least once :p
mddubya
Lol, no doubt, spend $200.00 on the boat, another few hundred trying to restore it, and then pay somebody another $100.00 to come haul it off when you get frustrated! :D
scutly
would make a good Viking funeral boat if it would float long enough to burn :p.... but thats about it
tashasdaddy
he is trying to save a trip to the land fill, and disposal cost.
