taking on water easy fix?
Wvawitrado
I can go all day no problem maybe run the bilge but I was wondering if maybe I resealed all the I/O parts coming out the stern it would help i noticed a leak at the bottom of the outdrive where it goes into the transom
180shabah
Re: taking on water easy fix?
If you have water leaking through the bellows, then you need to get that fixed ASAP. If the bellows completely ruptures, it can dump gallons per minute into the boat. Also, your u-joint and gimble bearing should never be wet(too late), so they probably also need replaced at this point.
bomar76
From the scant description could also easily be a rotted transom..
tashasdaddy
if you are taking water thru or around the bellows. it is time to pull the outdrive. that rubber is the only thing between you and sinking.
12vMan
Could be the seal around the outdrive also if someone previously pulled it and didn't seat it correctly.
