with a few runs now in the boat having one small problem. 25 1982 rude...<br /><br />When taking off after just starting the motor, it will die but if i pump the primer bulb it will keep it going, then usually after that all is well.<br /><br />i suspect 1 or 2 things.<br /><br />1 being i have only put one lot of fuel in it and used unleaded as i couldnt find LRP ( australia) would this have anything to do with the timing? making it run maybe a bit lean <br /><br />2 the twist hand grip is a bit dodgey and will skip off the gear if twisted too much , perhaps it has jumped a bit putting the timing in wrong spot
