scooper77515
- Sep 3, 2010
- 753
Previous owner stated he once thought starter was going out, bought new one, then when he went to replace it, found one of the mounting bolts was loose.
Well, I think while that bolt was loose, it nicked up the flywheel teeth.
Now, 90% of the time, maybe more, it just starts right up, but 5-10% of the time, it makes a racket and doesn't engage completely with the flywheel.
Starter looks new, I need to double check the part number and make sure it is the correct starter. The teeth on the starter look just fine.
I am wondering if starter isn't shooting the gear all the way out to fully engage with flywheel during those times it makes the racket.
There is a little bit of metal shavings below the flywheel, so you know that ain't right.
