Re: Tahoe Trailer Scraping
There are a couple of things one can do in this situation -- unfortunately both involve a little cash. If the trailer has a drop axle, replace it with a straight, cambered axle. That gains about 4 inches in height. If that's not an option, you can reposition the axle below the springs (if it is currently above them) but in most cases you need to add new spring perches or cut off the old ones and flip them. You CANNOT flip the axle (if its a straight axle) because most are cambered -- meaning it has an upward bow in it at the center. Taller wheels and tires only gain 1/2 the difference in diameter of the tire you switch to. In the grand scheme of things, replacing the axle is not a big dollar item when compared to other "boat stuff".
