Tahatsu 30hp ptt solinoid replacement
vgabbott
I need a diagram, photos, and instructions for replacing the A and B solinoid. The up stopped working. I suspect corrosion in wire connections since it started working again after push/pull on wires near rectifier. Where can I find detailed information? Thank you in advance for any assistance you can provide.
MattFL
Master Chief Petty Officer
Try https://www.manualslib.com/ . You might need to be creative and possibly find a similar motor if they don't have the manual for your exact motor, but I've had pretty good luck there finding information that I need.
pvanv
What is your actual model? 2 stk? 4 stk? Carbed or EFI? If 4-stk, the solenoids are on the front of the powerhead, and replacement is very straightforward. I would actually test the solenoids and verify wiring before replacing them willy nilly. Full info is in the Factory service manual.
