My Mark78A Engine has the tach wire's disconnected. It is a two terminal Faria Tachometer. I think one wire goes to ground - and the other goes to the ballast resistor. <br /><br />BUT - which side of the resistor? One side of the ballast resistor goes to the distributor and the other goes to a terminal post on the coil.<br /><br />My bet is it goes to the coil side.<br /><br />And finally - the ground side -- do I just ground it to the engine block?<br /><br />Thank's in advance -- <br /><br />Happy Labor Day Weekend ![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
