Tachometer replacement for a Nitro Ultra and Johnson 150 HP TJ150SLEIE
w2much
A couple of question here. My tachometer is bouncing around , I believe it to be bad. The batteries are charging. I have the wiring correct according to the manual and experience.
How many poles should it be set at for this engine?
Can a newer system check tachometer be used as a replacement.
Thank you in advance.
w2much
Tachometer issue on Nitro with a 150 TJ150SLEIE
