I have a 2005 Bayliner 192 with MerCruiser 3.0 engine which has 27 hours and is in second season. On the third time out this season, the Tach needle started bouncing back and forth between 3000 and roughly 4200 RPMs. The engine did not surge and all other instruments showed OK. This happened after I had cruised for about an hour at between 2800 and 3200 RPMs and then was at dead slow (about 800 RPMs) for about 25 minutes. After a while, the Tach would appear to be normal, then bounce around some more. This pattern continued until I pulled the boat from water. Everything appears to be operating OK, but I don't know if I have a potential problem.<br /><br />Any help appreciated.
